Please don't forget to check the Classifieds Guidelines before posting this classified ad. You many delete this text from your advertisement.
Item:
Tannoy System 1200 Speakers
Price: $1000.00
Item Condition: very good
Reason for selling:not in use/too much gear
Extra Info:
Description - The System 1200 nearfield monitor is part of the latest range of studio loudspeakers from Tannoy, a company with an outstanding reputation in the professional audio world.
The Dual Concentric driver might look like a conventional bass unit, but the system incorporates a high performance tweeter positioned immediately behind the centre of the bass cone.
This design produces all the frequencies from a single point, mirroring the way sound is produced in real life. The accurate phase response achieved delivers a realistic soundstage, along with a smooth and natural sound which is unfatiguing over long listening periods.
The speaker is capable of high volume levels without compression and delivers excellent transient response. The System 1200 is capable of producing accurate, high quality sound for a wide range of applications. The use of the latest materials and manufacturing techniques gives the System 1200 the ability to exploit the full performance of today's analogue and digital recording equipment whether in the studio, at home or in the theatre.
Applications
Music Studios
Mobile Recording
Broadcast
HiFi Systems
Post Production
Audio Visual
Home Theatre
Surround Sound
Quality Control
Technical Specifications
Frequency Response.....40Hz-20KHz +/-3dB
Recommended Amplifier Power.....100 to 300W RMS (8 Ohm)
Power Handling.....180W (Average)...350W (Programme)
Nominal Impedance.....8 Ohms
Sensitivity.....95dB / 1W @ 1m
Distortion.....<0.4% 40Hz-25KHz
Dispersion.....90 Degrees Conical
Crossover Frequency.....1.3KHz
System 1200 Dual Concentric Speaker
Compare these specifications with other speakers especially the distortion figures - less than 0.4% over the whole audio spectrum - now that's class and they don't look that bad either. Note also that these speakers are so sensitive that they can be driven very loud with even a modest output valve amplifier yet will take the output from substantial power amplifiers to give extremely high but clean output levels. As a main stereo (L+R) pair, the System 1200 speakers are unsurpassed for power, clarity and sheer naturalness.
Cabinet
Drive Unit.....305mm (12") Tannoy Dual Concentric
Low Frequency Design.....Optimised Bass Reflex Loaded
Volume.....74 Litres
Cabinet Construction.....MDF 36mm (1.4") front panel, 19mm (0.75") high density particle board
Cabinet Finish.....Baffle: Charcoal textured paint. Cabinet: Charcoal Vinyl
Dimensions (HxWxD).....396.5mm (15.6") x 648.5mm (25.5") x 472mm (16")
Weight.....27 Kgs (59.5 lbs)post-150841-0-63960700-1449975962_thumb.post-150841-0-83308900-1449975970_thumb.post-150841-0-50804000-1449975977_thumb.post-150841-0-60082700-1449975986_thumb.post-150841-0-18192700-1449975995_thumb.post-150841-0-70141100-1449976001_thumb.post-150841-0-11715600-1449976010_thumb.
Pictures:
