Gryphon tells us that the VANTA Series uses a highly unique Silver-Gold alloy for each individual conductor, which is then tightly sealed in a tube of PTFE insulation. That is then surrounded by a braided screen of silver-plated copper wires which, we are told, secures the best possible insulation and signal transmission. Finally, all of that is wrapped in a glossy black Polyurethane jacket.
All VANTA Cables are terminated by connectors supplied by leading manufactures such as Oyaide and Neutrik. The connectors are soldered to the Silver-Gold conductors under a microscope to make sure that all connections are soldered to perfection, says Gryphon.
The Gryphon Vanta Power Cable
From €3,800 for 1.5 meter
Gryphon VANTA power cable uk hi-fi news
The VANTA power cable consists of 2 x 13 AWG conductors and 1 x 16 AWG conductor made from Gryphon's unique silver-gold alloy. This is then wrapped in a braided screen of silver-plated copper wires. This is terminated with an Oyaide C-079/C-279 IEC connector with deoxidised phosphor bronze plated with 24K gold and palladium connector blades. At the other end is an Oyaide P-079/P-079e Male Power Connector which also features Connector blades of deoxidised phosphor bronze plated with 24K gold and palladium.
The Gryphon Vanta Interconnect Cable
From €4,800 for 2x1.0 meter
Gryphon VANTA interconnect uk hi-fi news
Here you have 2 x 16 AWG conductors made from the unique silver-gold alloy surrounded by a braided screen of silver-plated copper wires. The XLR terminations are by Neutrik and feature gold plated pins with a specially designed Gryphon housing made from anodised aluminium at the male end, whereas the female connector blades are made from
deoxidised phosphor bronze plated with gold for optimal contact.
The Gryphon Vanta Speaker Cable
From €11,800 for 2x2 meter
Gryphon VANTA speaker cables uk hi-fi news
The VANTA speaker cables are constructed from 2 x 13 AWG silver-gold alloy conductors wrapped in a non-active braided screen of silver-plated copper wires. The customised spade or banana connectors are made from gold plated solid copper in a specially designed Gryphon housing made from anodised aluminium.
The Gryphon Vanta 75 Ohm Digital Cable
From €2,900 for 1x1.0 meter
Gryphon VANTA digital cable uk hi-fi news
Both the 75 Ohm and 100 Ohm digital cables employ 2 x 21 AWG silver-gold alloy conductors with the braided screen of silver-plated copper wires. The difference being in the choice of termination with the 75 Ohm version utilising Oyaide's SLSB 4N Silver BNC connector with Teflon insulation whereas the 100 Ohm option goes with Neutrik XLRs. The males end featuring gold plated pins and the female end's connector blades being made from deoxidised phosphor bronze plated with gold. Both ends use Gryphon's special housing made from anodised aluminium.
For more information, visit Gryphon Audio Designs.
00005488
Posted in: Hi-Fi
